Replace Brake Backing Plate
Lincoln LS
  1. Ender570
    Ender570 LVC Member
    13
    Nov 27, 2015
    Shamokin
    For some reason, my front driver side brake backing plate is resting against my rotor and making a god awful squealing noise. I've ordered a new one, but I just realized that I don't see what fastener is keeping them in place on any of the diagrams. Does anyone know what I'll need, off hand?
    Also, will I have to remove the wheel hub in order to change it?
    It's a 2003 v8 with the sports package.
    Any insight would be greatly appreciated. It seems like it's always the small jobs where I overlook a small detail and out complicates the whole job :p
  2. joegr
    joegr Dedicated LVC Member
    19,378
    1,393
    Dec 10, 2005
    Gulfport
    I assume you are talking about the disc shield. Did you try just bending it back out of the way? I believe that it is held on by three rivets (W701950-S100).
    • Like Like x 1
    • 02LincLS
      02LincLS Dedicated LVC Member
      1,226
      17
      Feb 26, 2008
      N/A
      Yeah, its riveted. You might be able to use a machine screw with a low profile head and a nut on the back. I think you only need to remove the rotor.
      One of my rears had the rivet spot busted off and now it rattles over bumps. They probably pressed on it when they did rear bearings. I was thinking of just epoxying this one spot since I don't really want to drill a new hole in the hub/spindle.
    • FDR
      FDR Dedicated LVC Member
      1,872
      113
      Jan 20, 2014
      Central NJ
      I could be wrong, but looking at how my rivets made a clean hole in the shields, I'd guess the rivets are steel and the shields are aluminum, with galvanic corrosion eating the aluminum.
      I slopped some JB Weld over the area and zip tied it in place to let it set. They've held up for a year so far
    • 1LoudLS
      1LoudLS Dedicated LVC Member
      9,901
      350
      Mar 31, 2008
      Ann Arbor
      mine had a rubbing problem after hitting it taking the wheel off. I just bent it back out of the way.
    • amorgan2017
      amorgan2017 Active LVC Member
      141
      May 3, 2016
      Thumb Of Michigan
      Had the same problem. Just had to take the tire off and bend it back. No problems since.
    • RigsLS
      RigsLS Dedicated LVC Member
      7,761
      515
      Mar 10, 2012
      ^ next time, save yourself the trouble of removing the wheel and just poke a long screw driver through the spokes. Push on the shield all around just above the rotor.
      Usually after a brake job someone ends up with a slightly bent dust shield. Spreading the caliper is usually what causes people to rest said caliper on the flimsy shield. Unless your name is Loud1 and you lift wheels like a girl. Possibly some booze involved I'm thinking.
      • Like Like x 1
      • 1LoudLS
        9,901
        350
        Mar 31, 2008
        Ann Arbor
        I didn't have my Wheaties that day.
        • Like Like x 1
        • 1LoudLS
          9,901
          350
          Mar 31, 2008
          Ann Arbor
          it might have been the day I got a nail in the tire because the fater in law didn't empty some of the construction trash when he picked up a load of gravel for the drive way.
          EDIT: on second though, it might have been a week later when I caught the 2nd nail... I remember being awful mad and careless for a short time after that.
        • hite337
          hite337 Hite Performance
          2,700
          103
          Jul 5, 2008
          Grain Valley, MO
          I just used a 1/4-20 bolt (3/4" or 1" long, cant remember) and a teflon lock nut to refasten the dust shield to the knuckle after drilling out the rivets.. Works perfect.
        Share This Page
