Removing door panel?
LsPlayboy18
Palm Beach
My rear window broke and now i need to get the door panel off.. i took out the 4 screws and its still on there tight as all hell.. im not really babying it I just dont really want to break anyhting else. I did a search and only found some talk about "clips" which i have no idea about.. let me know if youve got any help
two screws in the pull handle
one or two screws on the bottom of the panal
one screw in the middle near the door latch
yank that bitch off, they are tough, you also need to take the black plastic piece off that is around the door handle
You need a new window regulator, no need taking the panal off if you dont have one.
Jay
are you sure its the regulator.. i did a search and some one with my same problem said all they needed was the plastic spacer..
Jay
two inside the flap at the bottom of the pull handle
three at the bottom of the panel
one at the door edge near the latch
pull the black trim off from around the door panel - screw behind that
http://www.lincolnsonline.com/article64.html
they make a tool that works well for taking off the clips. i would get one if i were you they are only $5-10. look like a flat screwdriver with a prong on the end. checkers auto has them
