Does anyone know how to remove the dash on a 2005 LS, was involved in a front accident so I need to replace both modules, air bags, and drivers side pretensioner
See this thread: Dash Board Removal Thread
It was for a 1st gen, but the 2nd gen is similar. Why do you want to remove the dash. Removing the dash isn't involved with, nor will it help with any of the items that you mentioned. The RCM is easily replaced without removing the dash, as are the driver and passenger air bags. The pretensioners aren't in/under the dash.
I was told the modules were behind the dash, and for some reason I can not remove the passenger dash airbag without removing the dash. I get the drivers side bag and clockspring are in the steering wheel and know how to do that, passenger giving me a hard time
Just FYI, you can access the crash/impact module without removing the dash. It is at the front on the floor underneath the climate control, you do have to remove the entire center console, but it is not nearly as involved as the dash removal.
