Radio Speakers are not working
Lincoln Mark VIII
  1. 582Boat
    582Boat Active LVC Member
    55
    Jun 24, 2005
    Battle Creek, MI
    In my 1996 MK VIII the radio was not working, therefor purchase a new JVC KW-XC410. I believe that I have hooked up the Scosche FDK10B/FDK 10 color coded wireing correctly. The radio is on, antenna goes up and down, volume shows, stations show, but no sound coming out of the four speakers.
    I have not been able to find the amplifier in the trunk or under the dash. I assume the radio was standard audio system, with out a cd player, etc. Need help.
  2. kylecm85
    kylecm85 Well-Known LVC Member
    300
    Dec 4, 2008
    lexington
    ok in the harness for the radio there is a all blue wire and a blue with white stripe the all blue goes to the antenna and the blue with white stripe is a amp turn on wire make sure that they are both conected and that should give you sound. If no luck there get a dmm and test the speaker wire behind the radio and make sure they are reading around 4 ohms. They will only read if there is not an amp.
  3. 582Boat
    55
    Jun 24, 2005
    Battle Creek, MI
    According to the Power Cord instructions of JVCKW-xc410, I hooked up Black to Black (Ground) Yellow to live terminal in fuse block(battery), Red toaccessory terminal in the fuse block, blue to solid blue, orange with white stripe to orange with white stripe(Illumination) To car light control switch. That left the Blue with white stripe wire empty, there was no other wire to connect to, question now what do I do.
  4. Jeffintampa
    Jeffintampa Dedicated LVC Member
    818
    Apr 19, 2008
    Tampa ish
    The amp is in the trunk up on the right side. You have to take the inside down, then unclip a hard plastic holder for amp. You could check if power is going in at least, and they are funky amps I am on my 3rd one
  5. kylecm85
    300
    Dec 4, 2008
    lexington
    Does your car have the black square plug that the speaker wires go in or is it a flat plug. Try hooking the blue with whit stripe to the straight blue wire that should work. If it has the square black plug then ur car has a amp and has to b turned on.
  6. ford nut
    ford nut Local nut case
    5,660
    81
    May 14, 2007
    Farmington
    Do yourself a favor, get new speakers and rewire the whole mess.
    Everything is 13 years old.
    That HU you bought will blow away the stock crap with any newer speaker you buy.
Share This Page
