radar detector install
o3sonicbluexlt
Green Bay
im lookin to install my radar detector with the wiring running down the a-pillar and into a fuse box. only problem is that the fuse box is either under the hood or in the trunk. what other wiring can i tap into to make this work?
I had circuit city wire up my v1 when they did my sirius and they tapped into an on/off wire with the car under the gauge cluster to the left of the steering wheel. whatever that panel is called where you need the door open to get it off on the side of the dash. jumble of wires back there they tied into. then you can run it straight up the a pillar or have the wires hidden behind the dash.
I can check what wire they tapped if you want later today.
If your mounting it high there is also a wire you can tap up near the rearview mirror. Not sure which one but i think there are threads on it.
I tapped my valentine 1 off the wire for the rearview mirror dimming/compass and ran it behind the headliner to the a pillar.
tapped my V1 power to a hot thats behind the drivers side footpanel..right under the hood release.
It's not a switched hot, but a hot that goes to zero volts apparently after a specified amount of time. I've left the V1 on before. Looked in the car an hour later, and it's off. As soon as I hit the alarm remote to disarm the alarm, I hear the V1 start up again. Must be on the same circuit as the cars dome light Im guessing.
