Dawkins said:Adding heat always works...when in doubt driving it off a cliff does the job...Or pushing in your case...
Dern Humpus said:Get a new nut, the threads are probably crudded up, or use a tap and retap the nut.
Brozly said:Can you split the nut, then a thread file or die to clean up the stud...
my95mark8 said:If I sell my Monte Carlo, will all my MarkVIII problems go away?
Cool...thanks for the tip.invisiblelincoln said:yeah, i sold my monte carlo, and then i went over to tell mrwilson, BAM, the ball joint came right out
