D
Deleted member 20330
Guest
After running through the rain, I sat in my car drying off with the climate control set at 80.
The expected heat output as usual.
But when the climate control was set to a cooler temperature, the climate control kept outputting 80 degrees.
This sounded like the blend door actuator problem.
I took the car to a local Ford service center (out of warranty) and they wanted $2,200+ to replace the climate control system.
I then took the car to a trusted repair shop where the mechanic fixed the problem in less than an hour for $75.
The mechanic said he "rebooted the computer".
As long as the climate control stays below 77, the temperature can be adjusted.
Is rebooting the computer nothing more than disconnecting and reconnecting the battery ?
Has anyone heard of this issue ?
