PCM code location
FDR
Central NJ
Where can I find the 4 character PCM code without an SCT scanner? Can I see it under the cabin filter assembly? Behind the glovebox? Would I have to remove the PCM to read it?
PM me your VIN and I can pull the PCM info.
Mine was on a sticker on the passenger side of the radiator core support, near the headlight. You might have some plastic to remove to see it.
