98markviii
Hi, I'm new to this forum and I'm looking for a little help. I recently purchased a 98 Mark VIII LSC Collectors Edition with 217k miles. I knew it was a lot but when I took it for the test drive, it ran well and seemed to shift well. I've always been a fan of big American luxury coupes and I immediately fell in love with the Mark VIII's styling. Well I drive it home no problems, except for the info center informing me of low coolant. I checked the level in the resivior and it looked ok, and the rest of the way home I kept a close eye on the engine temp and that stayed okay too. Now the car overheats and while the temperature gauge goes up it fluctuates when warming up. It'll jump higher than normal, then go back down, then go up and stay up (it may do this several times before it stays hotter) I never drive it close to the temp redline, even I know not to do that. But even as it gets hotter than engines normally do, the info center says engine temp okay when the system check is performed. I topped of the coolant, and it still tried to overheat, and I bought a new thermostat and hopefully will get it in tomorrow. But any input from fellow Lincoln owners would be a big help!! I'm only 17 with a part time job so I'm really hoping it isn't something expensive all input is appreciated thanks.
