myfirstls
OK. I thought I was done with the suspension overhaul, but guess not.
My left outer tie-rod end is frozen. I thought I'll take it to local mechanic to change it since I need it to get the alignment. But nooooooooooo. Pretty much all local shop tells me no bring in/customer parts to be install. So my option is limited. Because of where I live, I don't trust independent mechanic. that means I have to do it myself.
I know there's a hex built in the inner tie-rod, but that didn't help removing the outer. I tried wrench and vise-grip. Is there any other trick left? I thought about heating that sucker, but wouldn't that same heat travel to the inner t-e-rod, hence to the power steering fluid, but before that, the rubber booth on the rack-and-pinion?
I even tried to step on that thing (with care), but it didn't budge. I'm about to replace the inner because of this.
HELP!!!!
HELP!!!!
