This isn't a project I was looking forward to, but I decided I'd better get it over with before the days get any colder. For anyone who's in a similar situation, hopefully these pictures will give you some insight on what you'll be in for.
I started Sunday afternoon, and got everything bolted back together Monday night.
As you can see, I fastened the chains to the alternator bolts. They are screwed all the way back in to keep the stress on the bolts (and my block) to a minimum; these two little bolts will be holding the weight of the engine after all.
It will take several weeks for the enamel to fully cure. The heat from the engine will help a little.
In the meantime, since the enamel is still weak it's not hard to damage your new paint work while you're re-installing the pan, so put something underneath the pan (like cloth) to protect it while you're working then remove it after you've fastened it to the block.
New oil pan gaskets are about $30. Don't skimp out and try to re-use the old one, or you may get to do this again one day.
Pull your oil dipstick before putting the pan back on!
Tip: Rub some dish liquid onto your dry hands before you get started, and it will be easier to wash the dirt off when you finish.
