The front strut assembly can be modified to lower your Mark without sensor modification and without altering the factory predetermined front suspension airpressure.
As you sensor lower your Mark, the air in the bag will actually be lower the further you go down. By how much? I cannot tell you. You experience that bouncy ride with less air pressure in there. You all know what I am talking about.
By relocating the LCA to Strut attachment point higher up on the lower strut mount, you drop the front suspension at approximately
250mm. This mod can be applied to coil sprung Marks also.
If you still ride on air and desire an even lower front stance, combine this mod with the sensor lowering mod and you will be astonished by your Marks new performance. You will have a much firmer ride rather than just reliying solely on the softer, sensor mod. How else can you firm up the front without having to spend alot on inserts?
Here are some pictures I took before and after I installed my modified replacement struts. Careful measurments were taken to get the final results. There is a 0.20mm clearance between the Lower Control Arm and the lower Strut tube.
[/IMG]
[/IMG]
[/IMG]
The picture below shows the clearance a little better with backlighting. Overall, just like the rear air suspension mod, I am extremely pleased at my Mark ride quality. She has a nice lowered stance now but she rides like shes still at factory ride height.
[/IMG]
There have neven been any issues, noise or binding problems, whatsoever, ever since I completed this mod on my car.
I can post a short build write-up if anyone is interested. And as suggested earlier, I plan on starting a progress / build thread for Octane soon.
Since joining LVC, I have enjoyed reading everyones build thread and I would always look forward seeing what everyone is doing as soon after I finish watching Most Expensive Rides, Car Science, Motorweek, Inside West Coast Customs, Hot Rod TV, Rides, Ultimate Factories, MuscleCar, Pinks and PassTime!
