No plate light, trunk interior light or interior dome lights. What gives?
Scallywag
Franklin Park
Hi guys. Figured I'd quit lurking and chime in about a little lighting issue with the WF.
Yesterday I noticed as I was putting some groceries in the trunk that I did not have lights in the interior of the trunk and also noticed that the plate light was out as well. So I hop in the Mark with the idea to go buy some bulbs real quick but realized that the interior dome lights would not light up as well and figured it'd more than a bulb issue. Door ajar messages etc are correctly displayed so that rules out door jam issue. Regardless I still purchased a replacement plate bulb but got no light.
A quick search brought up this inquiry from last year that did not touch on specifics other than possibly the SCIL. All fuses seem ok, even #32 which I believe is for the SCIL, and am in need of some direction.
Are the 3 lights related or possibly three separate issues?
Any and all input is appreciated! Thanks!!
Could check the wire harness by the trunk hinge. Drivers side, they sometimes are a weak spot.
