so ive taken my 97 sts to a couple places and they cant seem to find the problem. I took it into crappytire and it came out with no break lights.go fighure. if anyone can help me let me know
thanks
ammi
have you check the connections? loose connection or poor grounding system is sometimes the cause why brake lights, gmc parking lights, turn signal, etc won't work.. also check the bulb, burned bulb should be replaced.. also check if there's some cross wired or something.. good luck
