M
Mesick Madman
Guest
Hi all, I am a new owner of a 91 conti, and would like some help figuring out a small problem it has.
As of right now, best I can do is run the engine while it sits on blocks, waiting on new struts (bad air bags all the way around). I am replacing them with non-air ride setup. After checking out most of the parts involved in the air ride suspension, I found all this to be bad:
Compressor, air dryer, 3 of the 4 lines, and all 4 struts. Dont be shocked, it sat for 2+ yrs as the former owner was tired of fixing it!
Suspension problem aside, the airbag light flashes 5 times repeatedly. can anyone help out by telling me what that code means?
Also, the trunk closing motor is shot, someone actually BROKE the motor out of the assembly! Easy fix there, just need replacement.
Thanks for all the help.
