need my heat its cold please help 90 mark vii
Lincoln Mark VII
  1. cinz4064
    cinz4064 Active LVC Member
    71
    May 2, 2008
    staten island
    if i put the climate controll on manual high 90 degrees it blows semi warm at an idle the car temp sits normal while idleing however when i rev the engine in park anywhere over 4k rpms the heater blows hot air until i let off the pedal i would be greatiful for any input you might have
  2. cinz4064
    71
    May 2, 2008
    staten island
    i think it may be the heater controll valve but would still like a second opinion thanks again
  3. fuzzmancometh
    fuzzmancometh Active LVC Member
    81
    Jan 4, 2015
    boston
    check your coolant level. its probably low
  4. cinz4064
    71
    May 2, 2008
    staten island
    just replaced the water pump and the thermostat pressure tested the system at 20 psi coolant levels are where they are suposed to be and staying i was having a run cool issue before i replaced th tstat ans found some debris keeping the old tstat open i flushed the system without the tstat in and put it all back together dont think its a low coolant issue
  5. cinz4064
    71
    May 2, 2008
    staten island
    still having the same issue does the heater blend door work off vacum
  6. Ricks90billblass
    Ricks90billblass Active LVC Member
    56
    Feb 19, 2007
    Sacramento
    More than likely a vacuum leak, or the diaphragm inside the door motor has ruptured and leaking.
  7. OldSchool1
    OldSchool1 Dedicated LVC Member
    2,043
    3
    Apr 11, 2004
    Primos, PA 19018 USA
    A rise and fall in discharge temperature with a set point of heater override at 90 degrees signifies an issue with flow, be it low coolant or (gasp) an incorrect water pump installation.
    1984 water pumps turn in the direction of our crank shafts.
    1985 - 1992 water pumps turn opposite of our crank shafts.
    If you tested the integrity of the system then fill the overflow bottle to HOT, run the car until it reaches operating temperature, shut it off. If your system is full and sealed, it should overflow.
    Test it and let us know what you find.
Share This Page
