dooneybaby
i changed all corresponding fuses.. next thing i was planning on doing is taking apart the steering wheel and cleaning it... but i dont know how to.
can anyone help?
can anyone help?
Quik LS said:it's the clockspring - a hub that sits under the steering wheel - at the top of the steering column - which has a ribbon cable that connects the horn, airbag and radio controls to pass from the steering column into the steering wheel and allow it to turn.
common issue with early LSes - the ribbon cable frays and your controls start acting up - or the airbag light fails on - or the horn stops working.....
a thread on the clockspring - > http://www.lincolnvscadillac.com/showthread.php?t=6316
aserrano said:My controls have gone crazy... the mute button is seek and the volume changes my media... is this another problem from the clockspring?? and also my cruise control doesnt work
I had this happen to a LS at my parents dealership and it ended up being the module itself..........not the clockspring. But first........check the fuses for the cruise control. If those are OK, then you would want to look into the clockspring given neither of your control modules are functioning properly. Who knows.........it could be a combination of the two.aserrano said:My controls have gone crazy... the mute button is seek and the volume changes my media... is this another problem from the clockspring?? and also my cruise control doesnt work
