04lincolnls
Well my battery is dead im gettn frustraited here and a bit overwhelmed. its drawin power somewhere im thinkin. had this problem last week, put a new battery in and thought it was solved even checked the new batt with a fluke meter to make sure it was holding the charge and it was doin well for the whole work week now dead again. I have been getting this audible poping sound jus once when the key is powered off or on that goes over the car speakers. I have the factory touch screen deck but it bearly works any more , only if you have the volume set to real low when you turn it up it just goes quiet. had aftermarket subs an amps in there sometime ago was thinkn mayb i fryed a wire behind the deck or something that mayb could account for the loss of power an the poping sound ..i pulled two fuses that go to the radio from the fuse bay on the passenger side floor but the radio still works wth is there a main some where else idk . anybody got any ideas for a guy . i need this car to be dependable thanks
