Module Viii
Henri,
Are you guys on target to begin shipping in April. I like it and will give it a try. Looking forward to slamming the car at will.
I looked at the site but am still confused on how it works. Are you in control of both the front and back or do you just control the height and the module calculates so that the front and rear are even???
Are you in control of both the front and back? YES
NO, when the Module VIII is operational, you have to make some fine tunnig. (directly on the second pod attached on the Module or moving the rear sensor manualy) This regulating are made once.
Due to the standardization of the computer the signal sensor is different between front and rear. The rear sensor signal is higher than the front
