k9t8m
Rollin' Twankies
Im about halfway through my kooks header install and an wanting a few pointers from you guys that have already installed them with the motor in the car.
This is what I have done so far:
supported motor dropped the subframe
removed the pass side cat and exhaust manifold
installed the pass side header (except rear top manifold bolt) < need advice
drivers side manifold is loose
egr hardware is stuck, i hanvt had a go with the torch, im hoping that does the trick
I can honestly say had i known this was going to be so difficult there is no way I would have taken this project on.
Can someone give me some advice as to how to get to the rear top of pass side?
Any tricks other than heat to get the egr loose from the drivers manifold?
