Jaguar Brakes Are they the same?
01LincolnLSV8
Riverside, RI
I'm looking into buying some rotora brake rotors, they have them for the jaguar S type 00 - 02. They are OEM replacement rotors. Does anyone know if they will fit on my Lincoln LS 01? I had my buddy look up part numbers for OEM rotors and the jag uses the same rotors as the lincoln. Will the caliper setup make a difference? I know the brake pads are the same as well Front and rear fitments... Can anyone verify this?
This is where i'm looking to get the rotoras from...
http://www.streetbeatcustoms.com/rotora-slotted-rotors-jaquar.html
The first two links are the ones i want to get...
Thanks,
--Josh
I'm with HyeLifeLS, should be the same, especially if you cross-referenced the part #. The R model probably has a bigger rotor and caliper, could possibly do a spindle swap, just a quess.
according to this -> http://www.designnews.com/article/CA86948.html
the jag and LS used different brakes and suspension compontents.
KEY:
Purple - different components
Blue - common components
Yellow - common elements tuned differently and/or having some different parts.
the is not to say they will not fit - as the rims do. Much of the sespension is not the same.
Anyone...
KEY:
hmmm i'm having some doubts now.... lol any one else? Ghost?
with all the options for the Lincoln LS why care about the Jag options?
i really wanted was rotora rotors.... what else is good thats not CNC machined? cause from what everyone says the rotors that are machined arent good they have to be molded witht he slots in order to be good.... correct me if i'm wrong but thats why i was lookin at the rotoras.... any suggestions?
