Idle........ Drop.
stink 'N linc 'N
Windsor
Today on my way home from work today , as i was accelerating the rpms would just drop just below 1 and i'd tap the gas, and it would go back up. Its about a 25 min drive.. It happend maybe 3 times. Want to get this fixed quickly.
Thanks!
Fuel delivery would be my first guess. Filter or pump. At those speeds I dont think the IAC would do that.
Filter is easy.... the pump is more work but not very hard. Lots of threads on how to do both.
My 93 has the tendency to idle like poo at redlights when its not warmed up. Examples are going to and from work. The rpms will drop from 800-below 500, shifting into neutral helps though? It wont do it as bad in park/neutral. I suspect IAC but dread doing it. Never seen a write up on it just hear how bad it is. At 118k I suspect the fuel pump isn't as good as it should/could be as well
Walboro 255 for the pump. Idk what my mechanic used for a filter
