towncarclownin'916
Can anyone give me advice on how to lower my 91 towncar a couple inches, I want it to sit at that "just right" stance over some 20's. I can't seem to find anything on the web to help me. :L
92 Arizona Towncar said:Towncars have completely different air ride suspensions then Marks' do... unfortunately there is no "factory" setting you can change as they are not changeable... You will have to go to a specialty auto store that will lower the car...
purelux said:If weight is added to the car or there is a leak you could do harm to the air springs or just sit too low i enough weight is added and not compensated for. There is a bar that slides back and forth (weight/height sensor) that gives the car the info it uses to set height based on weight. Besides that would get tedious doing that every time you get in the car or want it lower.
Here is a link to a crownvic forum regarding lowering with a rear air suspension:http://www.crownvic.net/ubbthreads/...d=allposts&Main=365813&Search=true#Post367881
97LTCSS said:the front...just clamp the spring...or cut it...and the rear...don't turn off the air ride...jack it up!!! then after like 2-5 mins...youll hear a click, that means the air is out...then when you lower it back down...the back should be slammed!!! just turn your car on...then at desired hieght, turn the air ride switch off!!!! there you go...thats what i did....check it out!!!
KainDTE said:did doing this to your car effect the way the car rides at all?
purelux said:I can't find the link to the picture but here's what I found.
Re: Air Susp. Ride level sensor
#18154 - 10/03/02 05:37 PM
Edit post Edit Reply to this post Reply Reply to this post Quote Quick Reply: Quick Reply
Yes, the sensor is on the left, lower, rear control arm.
The sensor is held on by 2 nuts, of which one is loosened (can't remember which). The sensor then is pushed up if you want the car to sit high, or pulled down if you want the car to lower.
