I just hit a Mattress on Road.....
Lincoln LS
  1. DMcBrideBoston
    DMcBrideBoston Well-Known LVC Member
    263
    May 3, 2006
    Murda Ma$$
    and punctured the oil pan.
    Its obviously dark out, so I cant see, is there anything blocking the oil pan from an easy or not too bad removal/install from happening..
    Like K member or Front Bar?
    Anyone had to replace one before?
  2. 97stscaddy
    97stscaddy Dedicated LVC Member
    2,238
    Apr 7, 2007
    Charlottesville, VA
    I believe the oil pan comes in two sections on these. Hopefully you just got the bottom section. From what I remember last time I was under the car, the lower part should come off pretty easily. Might have to take down some of the plastic splash shields.
  3. DMcBrideBoston
    263
    May 3, 2006
    Murda Ma$$
    Thanks for above reply....
    Update: Got it into shop today and mechanic hasnt had a chance to check yet, but it looks like it's dirty transmission fluid and not oil.
    This is great news for me so far...
    Hopefully it was just a few lines, but even if its the pan it should be too bad at all right?
  4. scjmc
    scjmc Dedicated LVC Member
    1,791
    12
    Nov 17, 2005
    Key West FL
    I can see why they threw the mattress out--it must have been very hard!
  5. DMcBrideBoston
    263
    May 3, 2006
    Murda Ma$$
    LMAO
    Mattress was being transported in the back of a pickup truck along with a few dressers and a box spring. Mattress fell off, I ran over it..
  6. pjm
    pjm LVC Member
    12
    Jun 15, 2007
    red deer
    I replaced the oil pan on my LS this summer. It is very easy to do and there is nothing in the way. It took about 15 min.
  7. hotrodlincoln93
    hotrodlincoln93 Well-Known LVC Member
    326
    Nov 29, 2004
    mt holly NJ
    man thats pretty F'd up.... i guess junk in the road is a possibility you shouldnt sleep on :D
  8. owlman
    owlman Dedicated LVC Member
    1,728
    15
    Dec 3, 2006
    Austin, TX
    *groan* :D
  9. DMcBrideBoston
    263
    May 3, 2006
    Murda Ma$$
    Well guys it turned out to be black trans fluid, it damaged the tranny cooler.
    My question is...
    Has anyone ever used an aftermarket (B&M) cooler in its place. like in between the radiator and the ac condenser?
    I have fitment worries.
    Thanks so much
    Dave
  10. King03LS8
    King03LS8 Dedicated LVC Member
    1,077
    Aug 6, 2007
    n/a
    So.....the idiot transporting the matress, he/she is paying for your repairs, correct?
  11. DMcBrideBoston
    263
    May 3, 2006
    Murda Ma$$
    the mexicans in old pickup bounced as soon as I hit it, no plates...
    I lose...
    they were prolly illegals
    all outta pocket hence the above Q about the B&M
  12. King03LS8
    1,077
    Aug 6, 2007
    n/a
    Get a CHL like myself and track them down, that wouldn't fly with me.
    BTW...was the matress worth a damn?
  13. DunItRight
    DunItRight Dedicated LVC Member
    706
    Aug 17, 2007
    Allentown
    I seen a bus hit a mattress once. That was cool but your case sounds like it just flat out sucks.
  14. DMcBrideBoston
    263
    May 3, 2006
    Murda Ma$$
    nope...I :q:q:q:qed it up prettty good....it was stuck under the car when the tow truck came, in between the two wheels, sideways....
    Sucked...
  15. King03LS8
    1,077
    Aug 6, 2007
    n/a
    The reason I ask is because a buddy of mine hit a mattress on the road too but when he stopped to take a look at his car and the mattress it turned out to be a tempur-pedic wrapped in high quality plastic and the truck drive never knew it fell off... so he took it home; I'd gladly run over one of those!
  16. DMcBrideBoston
    263
    May 3, 2006
    Murda Ma$$
    lmao, that'd be some good luck....
    I dont have any of that:mad:
Share This Page
