you will need to use a line output converter, to get a signal from the rear speakers for the input of the amp, you will also need a ACC trigger to turn the amp on, the easiest place to get both is behind the radio. then run the RCA's from the LOC to the amp, then run power wires from the battery to the amp, then run speaker wire from the amp to the speakers.
