'00 V8, 115,500 miles. Transmission was replaced at about 60k.
I drove the car from Atlanta to Asheville and back. It's about a 3 hour drive one way. On the return trip, after I'd exited the interstate, the transmission started to slip when i started from full stop under light acceleration. It was at the first shift point, but I don't know if that is 2 to 3 or 1 to 2 in these cars.
The thing I didn't notice in the many other "transmission slip" threads is that I could hear a slipping / whine or light grinding under the rear seats until the transmission "caught." It kind of sounds like my old Accord manual did when the clutch needed to be replaced.
From the other threads, the suspects are:
- Solenoid pack - I had this done three times on the original transmission, and this doesn't feel the same. Shifting to reverse is fine. There was no sound during those problems
- COP's - I can see the hesitation making sense, and it's similar to when I had COP's changed before, but how do you explain the sound?
- Torque converter (?) - When this has failed on our old Pontiac the car would die as you came to stop
- Transmission fluid - This one is making sense to me, probably because the last option is so bad
- General transmission failure - Hoping that's not the case
Any thoughts?
Any thoughts?
