Did you read the owners manual?
whenever i turn on the heater the AC light turns and i can hear the compressor turning on too why? is this normal?
Works as designed.
a design flaw
the flaw is that it turns on automaticaly when its not needed there is a button with a light that says AC on it if i need the air conditioning i will push that button otherwise it should not turn on during winter every time i turn on the heat!...i wonder if i leave it on will i have ice cold air coming out of one vent and hot air coming out the other
...by "blower" I assume you mean the fan pushing air through the vents?
Yes.
If having the AC compressor on causes any reduction of the maximum heat available, you have a problem somewhere (Aux pump, DCCV, air in coolant loop, faulty temp sensor, ...)
Excellent responses Joe. Members should read OM to be aware of the capabilities of a vehicle and the normal operation of the equipment.
EXACTLY why rain-sensing wipers were discontinued. Too many warranty claims. Owners didn't read the OM and therefore didn't understand their proper operation.
I hate them.
