How big of a job is this? Would I be able to pull this off myself?
SECTION 303-01: Engine
2006 Lincoln LS Workshop Manual
IN-VEHICLE REPAIR
Procedure revision date: 06/24/2005
Engine Mount Printable View (378 KB)
Special Tool(s) Lifting Bracket, Engine
303-050 (T70P-6000)
Three-Bar Engine Support Kit
303-F072
Item Part Number Description
1 6A005 RH engine mount upper nut
2 6754 RH engine mount lower nut
3 6754B RH engine mount
4 W500234 RH engine mount bracket bolt (3 required)
5 W705399 RH engine mount bracket stud bolt
6 6061 RH engine mount bracket
7 6A005 LH engine mount upper nut
8 6754 LH engine mount lower nut
9 6754B LH engine mount
10 W500234 LH engine mount bracket bolt (3 required)
11 W705399 LH engine mount bracket stud bolt
12 6057 LH engine mount bracket
Removal and Installation
Both sides
CAUTION: The engine appearance cover is equipped with a noise suppressor. If the noise suppressor becomes separated from the engine appearance cover it must be positioned on the intake manifold prior to installing the engine appearance cover.
Remove the engine appearance cover and the noise suppressor (if detached).
Remove the air cleaner outlet pipe.
Remove the upper radiator sight shield.
Install the special tools and support the engine.
RH side
Remove the RH lower splash shield.
Remove the nut and disconnect the transmission cooling tube support bracket from the engine mount bracket.
To install, tighten to 10 Nm (89 lb-in).
Remove the RH engine mount upper nut.
To install, tighten to 50 Nm (37 lb-ft).
Remove the 3 bolts, the stud bolt and the RH engine mount bracket.
To install, tighten to 46 Nm (34 lb-ft).
Remove the lower nut and the RH engine mount.
LH side
Remove the LH lower splash shield.
Remove the LH engine mount upper nut.
Remove the nut and the power steering tube support bracket.
Remove the 3 bolts, stud bolt and LH engine mount bracket.
Remove the lower nut and the LH engine mount.
Both sides
To install, reverse the removal procedure.
