Harmonic Balancer Bolt Torque Value
LS 2006
Ravenna
Wondering what the torque value is for the bolt for the harmonic balancer on 2006 LS with 3.9L engine?
Can the original bolt for the harmonic balancer be reused?
Thank you in advance.
The book says that you must use a new bolt. I know people who have reused the old one and AFAIK, their dampers haven't fallen off yet. At one time, the bolts and the dampers were hard/impossible to get. I think that may have changed and they may be making them again. Also, you may be able to get the bolt from Jaguar.
NOTE: If the crankshaft pulley is not secured within 4 minutes of sealant application, the sealant must be removed and the sealing area cleaned with metal surface cleaner. Allow to dry until there is no sign of wetness, or 4 minutes, whichever is longer. Failure to follow this procedure can cause future oil leakage.
Apply a bead of silicone gasket and sealant to the keyway.
Using the special tool, install the crankshaft pulley.
Install a new bolt and tighten in 4 stages.
Stage 1: Tighten to 80 Nm (59 lb-ft).
Stage 2: Loosen 2 complete turns.
Stage 3: Tighten to 50 Nm (37 lb-ft).
Stage 4: Tighten an additional 90 degrees.
