Kevin O'Connell
OK, this week the serpentine belt starts to howl a bit when cold starting. Thought maybe the belt was shot and slipping or the tensioner was failing or idler pulley bearing was going bad. After listening to it, it sounded like the alternator was full of marbles while running- cool- alternator still under warranty, autozone gets me one, I pull it off and start checking things out. Tensioner OK, idler OK, alternator smooth and free. Oh :q:q:q:q, grabbed the water pump shaft and its only got maybe 3/8" axial movement in the shaft and just started to leak.
Autozone in the morning to get pump. Started WD-40 treatment on coolant tube cap- I hope it comes loose OK!
While its apart, what thermostat should I get so I do it all at once? 160, 180, high flow, what?
What's the best procedure for draining and refilling and burping all the air out?
