chris2523
93 Mark VIII
so my car has a miss. i noticed it friday.
slightly rough idle and a slight hesitation right off idle. pulls cleanly in all gears, but feels down on power.
ran the codes. didn't find anything relevant. some IAT and MAF codes from when i had the intake tube off.
removed my chipped computer and the problem remains.
chip problems eliminated.
code check on the new comp revealed a 111 after some drive time.
cylinder balance test gave me an 8, 8, 9.
so my problem lies in cylinder 8. unplugged the fuel injector and restarted. yep. not much change.
plugged 8 back in and pulled injector 7. everything got much worse.
so tomorrow i'm gonna pull the plug and wire on 8 and see what's up.
if the head gasket is leaking i will see a clean plug correct? since its like being steam cleaned.
i am low on coolant occasionally, but that's nothing new. its always been that way.
i know these cars have head gasket problems around cylinders 7 and 8 so i'm kinda worried.
anything else i need to check? it really ran pretty great right before this.
