I've searched and even discussed this a little bit in Telco's "Engine Noise" thread, but no solution ever came up, and I'm having trouble narrowing the noise.
Other members including alex talked about a "rattle" when under load like getting on a highway or up hills.
I especially hear the rattle going up hills, I think the torque converter is supposed to fully lock when this happens because i can hear the rattle as soon as the RPM's drop going up a hill.
Some said cats, but it only happens the car drops to lower RPM's on hills, getting on highways etc. I've read around the net, some say coils, some say rear diff, some say throttle position, tire pressure....on and on.
It's a re-built 2002 3.9. I replaced transfluid, filter, and a new torque converter from american hot rod solutions and had it running since February 2012, with only 12,000 miles on the clock so far since the rebuild.
Question is, is this rattle a possible TC issue with only 12,000? And how can I check to verify if it is the TC? I've heard some say something about hitting the break pedal when it happens - something about a switch that makes the TC go into full lock. I did get under the car and knock the flywheel to see if it was cracked and it rang like no tomorrow so I'm guessing it's good
