what if i fill up with regular gas and and add an octane booster will that help cause here in el paso tx we have regular, plus and super unleaded and super unleaded is the 91 octane and its like 30 more cents than regular, and the car hasnt made a ping or knock yet
How to make your own octane booster.
Things You'll Need:
* An empty quart container
* An empty half pint container(for ease of measuring)
* A small funnel
* 1 gallon acetone
* 1 gallon xylene
* 1 quart good quality synthetic 2-cycle oil.
* (All the above ingredients I found at a local Home Depot)
Obtain your supplies from a hardware store. The Synthetic 2-cycle oil may have to be obtained at an auto parts store, but I have found it in the lawn & garden section of most hardware stores. The acetone, and xylene are both paint thinners, so they are in the paint section. Xylene is a component already added to gasoline for stability, and acetone cleans build up and breaks down the covalent bonds in petrol. The 2-cycle oil helps upper end lubrication of the engine, and stabilized burn a little also.
Step 2
The mix ratio is 2:1:1 acetone/xylene/oil, respectively. For ease of mixing use the half pint container, plastic, cleaned out of original contents of course, and fill it with acetone pour with funnel into the quart container(oil bottles are perfect), do this twice. Now fill it once with xylene, pour into quart, and again with the 2-cycle synthetic oil. 1/2pint x 4 = Quart of homemade octane booster.
Step 3
Add 3oz. of your booster to 10 gallons of gas.
i still recommend paying the extra money for the super, we all have to do it, if you cant afford the price of gas, you wont be able to afford to fix the car if it messes up.
