Grill: The top was chrome and I painted silver. Not perfect color match but very close to JP silver birch. For additional cost I could color match for you. All of the studs and clips are intact so you could use just the bottom if yours is broken. The emblem has a stone crack in it but I polished it so it looks clear. Reuse your emblem if its in better shape.
Alpine 6 disk in dash from my '02. Display works fine. Was only in car for 3 years. Speakers all work properly. Amp is still in car but can be removed if you need it.
Stock air box snorkel
Driver Side (L. Side) Mirror: Good for parts. Housing is broken but mirror functions without issue. Paint code is silver birch JP. Studs were broken and gorilla glued back on and reinforced with epoxy. I used it this way for over a month without issue. It could be repaired and used.
