00ls5spd said:Yeah I removed the trunk lining and dynamat'ed the whole thing ...I mean the whole thing ever thing I could cover is covered, even down to behind the license plate surround. I have a spoiler an that still rattles a bit, I would also suggest dynamating behind your license plate just as added backup.
00ls5spd said:I am running all stock in the doors so it didn't matter to me. But if someone is running a complete custom system with like some 8's in the doors with some tweeters then I would go for it, but I wouldn't hassle with it for stock.
That's good, the LS trunk lid and hood feel flimsy. How much did you pay for the trunk lid?Joeychgo said:I did it on my Mark VIII and it also made the trunk lid feel more "solid"
executivechef01 said:its roughly about 300 or so for your trunk. dont do your hood it will contain the heat and prol. cause engine trouble and who knows what else.
Be careful with the foam because it can cause your trunk lid to warp. I would try to stay away from the foam IMO.Black03 said:I have 60 sq ft I'm needing to put on my doors, then I'm gonna get some expanding foam that you would find at home depot and put that inside the trunk lid so it is solid, finish it off with a layer of deadener. That should be good fo what I'm doing, only around 2000 watts or so.
