dnsherrill
My White Car is not recharging; with the lights and a/c on it takes about 10-20 mins at idle for the bat to drain down to about 10 volts. I used a bat that I know is good and tried 2 alts:
(a)the white car's orig factory alt (120k miles), and
(b)the factory alt I took off my brown car at about 170k miles- it was functional when I removed it, iirc
I took them in to vato zone and tested both generators: alt(a)passed and alt (b)failed...I expected the opposite
time to open the service manual: does anyone have a photo of where these 2 fuse links are located? are they just a smaller gauge wire (12ga) that becomes exposed to open the circuit?
any theories on why I'm draining/not re-charging? is it common for these to fail? maybe something elec got wet when I pressure washed awhile back:slam
I guess there's a ground somewhere on the block I should check? I've yet to compare the alt (+) and the bat(+) voltage.....charge at the bat does not go up if I rev the engine; I don't know how to check current from the generator
