Suppose you bought a vintage Mustang and you’re not sure what gear ratio is installed in the rearend. You can simply plug a few numbers into this next formula to determine what gear ratio you have now or to determine what gear ratio you should be running for the rpm range you want to be in at a certain mph. This is the formula for determining gear ratios.
