SATURN5
Dr. Frankenstang
Went to pull the front wheels off today to have some new tires put on, and the jack slipped off the cross member...
Which then let the full weight of the car slam into the jack and the pan.
Got the jack repositioned and car up on stands, and see the pan is shoved up.
Went and got the tires done, and gave me some time to brainstorm a fix.
I figured I'd weld a couple nuts to the pan, take a long bolt and some tube and lever it back into place.
Well, it worked... Sort of. Something is hitting when I crank/start it.
So, the boys and I shove the SVO out of the garage and shove the Mark in.
Looks like I get to drop the cross member and pull the pan and see what I've buggered up.
All I wanted was to replace my tires...
