xtriggerman
Well, I updated my relocation How Too article since I had a leak...again. Hoping to swap in a Trans Dapt head was even a BIGGER disapointment! But there is a fix to every problem and I outlined the fix to the most desirable solution. You can read about it at the end of the original article.
www.lincolnvscadillac.com
DERALE oil filter relocation kit project
Probably the most disliked thing about changing the oil filter on my 97 is the fact that you have to spin it on dry. As every one knows, cold start up is when the bulk of engine wear happens according to the experts. So add a dry filter and you...
