Dccv Help!!!!!!!
tdymorris
Magnolia
I had a problem in which, no matter what temperature i set the climate control to it woould blow hot as balls. I read on here that would be a DCCV problem. I replaced the DCCV, now it dosent blow hot as balls anymore, but not cold. Back when i bought this car the air blew cold as :q:q:q:q. then this whole fiasco happened. Any ideas?
Pinch off the hoses going to the heater core. If you still don't get ice cold air, then you are likely to be low on R134. Which would mean that you have a leak to find and fix.
If you get ice cold air with the heater hoses pinched off, then you either have a bad DCCV (even though it is new), or a problem with the climate control electronics.
Good advise, what I found is that you have to make sure your coolant level is up and you must bleed the system properly. When you do all that set the hot temperature as high as it goes then go back to cold and check.
Worked for me.
