Cooling fans
foxpaws
Denver
Well, I might not get any answers - but, just in case the normal sources come up empty... And you never know where a N* mechanic might lurk....
So, I was in a big butt Eldo recently, a N*, and I could really hear the cooling fans, and they even remained on after the car was shut off...
Amante - nothing. I have never heard the fans - and never has anything been running after the engine was shut down.
It isn't like he hasn't been driven in hot weather - 100 degrees - in traffic... the temperature bars have gone up to 1 above normal (for a minute or two, then back down to normal), but that is it. Never overheated, or anything, and never any fan noise.
But, I am beginning to wonder if the fans aren't working. Is there a way to test for this - and since I bet there is something wrong - probably a relay - right? Hard to replace - or do you need to be an Italian mechanic to do it correctly?
Ran codes on the DIC and nothing there either...
Thanks....
brentalan
Alpha, NJ
take the car for a ride, get it up to temperature and then park somewhere and let it run. The fans should come on after a few minutes (I'd wait a good 15 minutes to be sure) because there is no cooling to the radiator. If they don't, the alternative is the temp gauge will start rising.
BAD97LSC
Palm Harbor FL
exactly, turning the a/c to max air will make the cooling fan come on even if the car is cold.
foxpaws
Denver
Thanks guys, they are spinning up a storm, I did the A/C test - however they are the most quiet fans I have ever 'not heard'... I put my hand in front of the radiator and I can really feel the air being pushed through.
Well - at least this summer if I decide a cross midwest trip is in the stars - the old boy should be happy... and cool...
cornerway
USA
It could be busted thermos-witch sensor that is why its not working automatically.
