JoshMcMadMac
I have a 2005 V8 LS. I had noticed that the radiator fan was running at full speed when I would park it, even though the temperature gauge was in its normal location. Using my scanner I found that operating temperature was getting to 235-240°. The degas bottle was a little low, so I topped it off and that resolved the issue for a few days. Once the fan started running high again, I looked harder and found that the plastic portion of the upper radiator hose was weeping. I replaced it, and have bled the system verbatim to the shop manual more than once to no avail. I have bled the system before without incident. The heater is running nice and hot. I am not convinced it is an "overheating" issue, as the car seems to be stabilizing right at 235° no matter what...I can idle in the garage forever, or drive down the interstate at 60MPH in 30° ambient with the heat blasting and it makes no difference. Are there any tips or tricks that I am missing?
