Question guys. 2004 LS v6 with 147k miles. coils have been replaced around 80k from previous owner. after i changed out a cat and o2 sensor, i got a cylinder #1 misfire code. most likely bad coil because im getting the infamous misfire while the engine is cold and then runs fine when its warmed up. has anyone succesfully replaced the coil #1 without removing the intake manifold? i can see the coil and can have access to it but not sure if i can pull it out without taking off the intake. any input helps. thanks!
Justin
Justin
