Does anyone have some good advice how to clean the engine. Is there any special cleaner to use and is it ok to spray the engine with water at a car wash. Just want to make sure i dont hurt the engine while cleaning it. Thanks for the help.
SC_Steve said:what I do is drive the car up to the car wash (engine COLD). Soak it down with some simple green and let it soak for a good 10 mins or so. Pull it into a wash bay, cover anything you don't want wet. Hose it down and wipe off any excess grease/grime
works like a charm
Sifrino3 said:At most car washes there is something for an engine clean. Its green at our car wash. I used it one time awhile back. I havnt used it since. Reason I used it, had a leak in the power steering. Then got it fixed. Then got it cleaned. (84 LSC OVR CST)
