For Sale Car audio: JL Audio, ARC Audio, RE Audio
Non-Auto Stuff For Sale
  1. tirefryr
    tirefryr Active LVC Member
    79
    Jun 5, 2010
    IN
    Contact Seller
    I'm selling some of my car audio gear to purchase another Gen 1 buy, so.. . . . .
    First up is a MINT pair of JL Audio slash series amplifiers. I have a 1000/1 and a 450/4. These are great matching amps. No marks aside from the screw holes and used very little. The 1000/1 will supply 1000 watts at any impedance between 1 and 4 ohms. The 450/4 will provide 4 channels of staggered power with 2 channels supplying 75 watts and the other 2 supplying 150 watts into any impedance 1-4 ohms. Both have built in crossovers, but the 450/4 gives you the option to bandpass as well making it very handy for 2-way active.
    I'm asking $650 plus shipping for the pair and I really don't want to separate, but money talks. Just to give you an idea, the 1000/1s have been selling on Ebay for around $500 still. They hold their value quite well.
  2. tirefryr
    79
    Jun 5, 2010
    IN
    Next up is a MINT JL Audio 8W7 anniversary edition. This little puppy is an AMAZING driver. I used it for a couple weeks in the JL spec vented enclosure and it was too much for me. People thought I had a pair of 12s in the trunk. It's really an amazing driver. I will include the enclosure if someone wants, but shipping will be expensive. I'd like to get $250 shipped for this.
  3. tirefryr
    79
    Jun 5, 2010
    IN
    ARC Audio KS1200.1 This is BRAND NEW IN BOX. I have pulled it out for photos, nothing else. HAs never been mounted or powered up aside from factory testing. This thing retails for $700 online. I'm looking for $400 shipped OBO.
    specs are 650x1@4ohms, 1200x1@2ohms, and 1000x1@1ohm.
  4. tirefryr
    79
    Jun 5, 2010
    IN
    Finally I have a pair of RE8, 8" subwoofers. These are the original drivers before being bought out by US Amps and having the products made in China.
    Specs:
    Suspension: Santoprene rubber surround. Conex spider.
    Frame: Stamped steel basket.
    Voice Coil: 8-layer copper voice coil.
    Fs = 22.8 Hz
    Qms = 4.21
    Vas = 0.957 cu.ft
    Xmax = 0.472 in
    Xmax (parallel) = 0.472 in
    Xmax (series) = 0.472 in
    Sd = 30.23 sq.in
    Qes = 0.76
    Qes (parallel) = 0.38
    Qes (series) = 0.38
    Re = 3.2 ohms
    Re (parallel) = 1.6 ohms
    Re (series) = 6.4 ohms
    Z = 4 ohms
    Z (parallel) = 2 ohms
    Z (series) = 8 ohms
    BL = 1.731 lb/A
    BL (parallel) = 1.731 lb/A
    BL (series) = 3.462 lb/A
    Pe = 87.5 watts
    Pe (parallel) = 175 watts
    Pe (series) = 175 watts
    Qts = 0.64
    Qts (parallel) = 0.34
    Qts (series) = 0.34
    1-W SPL = 78.1 dB
    1-W SPL (parallel) = 81.2
    1-W SPL (series) = 81.2
    They are the bottom two drivers in the middle in this photo.
  5. tirefryr
    79
    Jun 5, 2010
    IN
    Anyone? Offers?
Share This Page
