Looks like the rear toe link......
Exactly, and the whole toe link needs to be replaced (both should be).
That looks like the rear lateral arm. I just replaced mine last month, ordered them from TascaParts.com. You'll need an alignment after.
He should not need an alignment if its done right. Don't make it harder than it is.
So you're trying to say that i need to replace my whole "rear toe link" but the only thing that seems to be the problem is the rubber bushing that i have circled. can someone send me a link to where i can buy the rubber bushings. thanks.
The boots are not available separately.
Alternative cost effective solution = Jaguar's version (JA-L607) of the Toe adjust end linkages.
You'll lose the passive steering on it vs. going with the more expensive FORD OEM linkages.
Stabilizer Link JA-L607 XR825750 6W4Z5B551AA 101-6784
http://mibearings.com/index.php?main_page=product_info&products_id=84502#axzz2ziELBkwR
$64.05 each, you really should change out both units at the same time.
Products
2 x Stabilizer Link JA-L607 XR825750 6W4Z5B551AA 101-6784 (JA-L607)
Sub-Total: $128.10
GLWR
Am I correct that the cheap versions like http://www.ebay.com/itm/170683939508?item=170683939508&viewitem=&vxp=mtr
Those do not have the passive steering? This is a feature I want to eliminate.
Passive Steering? What is that?
Exactly how do you "do it right" such that you don't have to do an alignment?
Found the answer in this: http://www.lincolnvscadillac.com/fo...Rod-Lateral-Bar-options-other-then-ford/page3Lay the old ones next to the new ones and make them the exact same length. Some people trust this, other don't. It's usually a "good enough" as opposed to "is this good enough..." mentality.
Products
Sub-Total: $128.10
GLWR
... These deeza parts are even listed at the very bottom if you use the rockauto.com breakdown for the LS in the suspension tab.
I tried this when i replaced mine, but after a week decided to get an alignment anyways and the alignment was way off...
No offense ... but the idea is that one would dial it in as close as possible by means of putting the old/new linkages side-by-side, adjusting it so they both sit centered at bushing hole to mounting end, install & tighten it, lower the car to ground level & retighten THEN drive it to an alignment specialist for a four wheel alignment.
It prevents one from chewing through a set of rears by the time one would arrive at the alignment shop.
RockAuto Parts Catalog
VS.
MIBearings LLC
http://mibearings.com/index.php?main_page=product_info&products_id=84502#axzz2ziELBkwR ... SAME PART !!!
Those that just eye-ball it and call it a day, most likely end up shopping for new tires by that weeks end.
Now should one have a red light level laser at ones disposal
... DIY four wheel alignment j/k
