Here is a list of items/part numbers being used to convert my Mark VIII hubs over to Mustang 5 x 4.5 bolt pattern, and also what is needed to convert the fronts over to a Brembo 4 piston big brake setup.
Please note that you will need 18" rims to clear the Brembo's. Even then, check with your rim manufacturer to make sure that your 18's will clear them. I had to have my rims custom made to clear the Brembo's. I will post pictures of the install in 2 weeks.
M2300X Ford Racing/Brembo 13in 2000 Cobra R Front Brake Kit
136-2261002 Baer Eradispeed Extreme Plus 2 piece Front Brake Rotors for 1999-2004 Mustang Cobra
DP31031C EBC Brake Pads for 2000 Cobra R/Brembo Brakes
9904HABA Front Hub and Bearing Assembly for 1999-2004 Mustang Cobra
136-2262001 Baer Eradispeed Extreme Plus 2 piece Rear brake rotors for 1999-2004 Mustang Cobra
YR3Z1109AA Rear Hub for 1999-2004 Mustang Cobra IRS
E9DZ1215A Rear Wheel Bearing for 1999-2004 Mustang Cobra IRS
BR57B Rear brake pads for 1994-1998 Lincoln Mark VIII
Big Ed's Caliper Relocation Kit
Classic Tube SS Brake Line Kit
