brake light.....
Silver_LS
Maple Lake, MN
eletrical problem ... or its telling you the bulb is about to burn out :D
sorry... i really don't know.
joegr
Gulfport
It either going to be the REM or a short to ground in the wiring between the bulb and the REM.
01LSV8TX
Funky Town
it's the left brake light and the third on the spoiler, but that is just wired into the left. definitely not the running light. What is the REM?
PetesSweets86
Seattle
Wow...tha'ts gonna get ppl angry if it's stuck on.....haha...I'm pissed off at all these :q:q:q:qty drivers that can't seem to find the turn signal switch......lazy asswipes :/
joegr
Gulfport
replace it? where is it? its just the left, not right.
In the trunk, behind the side trim panel on the right-hand side. Make sure it isn't a wiring fault first, I suspect this module isn't cheap. The factory manual says that the replacement module has to be programmed to the car with the factory scan tool. This may not be true, I don't know.
97stscaddy
Charlottesville, VA
IIRC the brake lights on these cars are negative ground, so its probably a short somewhere in the wiring for your spoiler.
