Kirk Washer
- Joined
- Jun 11, 2015
- Messages
- 11
- Reaction score
- 0
Just wondering if anyone here has removed the read subframe (k frame) from their lincoln LS?
How hard was it?
How hard was it?
I've done mine 3 times. If you have a lift, it is not too bad. It does require some thought, however. You need to drop the exhaust from the cats back, then remove the heat shield and drive shaft, pull the calipers and suspend them free of the sub frame, and disconnect your e brake cables or whatever setup you have, then you will need to remove the 4 long bolts for mounting the sub frame to the car body. They can be difficult, if you live in a rust belt state. Be prepared for some heavy weight when this is ready yo come down. If you work from the ground and not a lift, you may need a transmission jack to accept the weight, as the differential and axles add a lot of weight to the assembly. I left my control arms on and I believe that I disconnected the shocks from the lower control arms. Once safely supported on the floor, I was able to remove all other parts. I did this because I had three failures of the body mount bushings. I was able to replace the bushings through a jaguar S type part retailer, since they sell the bushings, unlike Ford, who only had a complete rear sub frame as a maintenance philosophy, nothing smaller. The old bushings were able to be burned out of the sub frame. They burn around 20 minutes and make a heck of a mess since they flow out liquified rubber when they burn. Make sure if you do this, you do this outdoors. I think that the old bushings could be pressed out instead of burning.
No, the front two are the same and the rear two are the same, but they are different from one another. I have yet to see a rear bushing go bad, though. All 3 of my failed bushings were the front left one on the rear sub-frame.Mike -- are all four of the bushings the same? It looks like I am going to have to replace these bushings on my '02.
