Anyone know what 15" wheels will fit the LS?
Lincoln LS
  1. ga289stocker
    ga289stocker LVC Member
    22
    Jan 25, 2015
    Atlanta
    I have a set of 235/60/15 BFG DR's that I would like to mount on a 15" rim for the track. I know the bolt pattern is 5x4.25". Anyone know what cars have that pattern in a 15" wheel that will fit the LS and clear the brakes? Thanks.
  2. LS4me
    LS4me Dedicated LVC Member
    9,973
    272
    Apr 23, 2004
    San Diego
    I'm sure Google knows.........
  3. chris2523
    chris2523 93 Mark VIII
    7,895
    263
    Nov 8, 2007
    Central MO
    i'm not actually convinced 15s will clear the rear brakes.
    the "general rule" seems to be rotor+4.
    the LS rear rotor is 11.34+4 = 15.34.
    rounded up to 16.
    and i can't say i've seen this tried so you may be alone is this.
    i'd start with a taurus 15" wheel from the junkyard and see where that gets you.
  4. JoshMcMadMac
    JoshMcMadMac Dedicated LVC Member
    3,514
    27
    May 3, 2004
    Waynesboro, PA
    I know you are talking about the rears, but just in case you are considering all four corners...the front calipers barely clear stock 16" wheels.
  5. LS4me
    9,973
    272
    Apr 23, 2004
    San Diego
    What he said!!!
    Then again you could always use spacers....
  6. FDR
    FDR Dedicated LVC Member
    1,987
    135
    Jan 20, 2014
    Central NJ
    I tried fitting a steely Taurus16x6.5 or something (full size spare) and I don't think that even cleared the brake with the way the steel face curved in towards the barrel... but I could be wrong.
    Josh, I think what Chris was saying is that 15s might not even fit the rears, let alone the fronts.
  7. 1LoudLS
    1LoudLS Dedicated LVC Member
    9,904
    353
    Mar 31, 2008
    Ann Arbor
    so I'm the only one who is curious as to what has been done to this LS that it needs drag radials to get traction???
  8. JoshMcMadMac
    3,514
    27
    May 3, 2004
    Waynesboro, PA
    Oh, I was not addressing Chris...good point. I should have quoted the OP. Thanks, Frank.
  9. ga289stocker
    22
    Jan 25, 2015
    Atlanta
    Ahh, well when you stomp the gas with your right foot does your LS NOT smoke the tires from take off? Already had the DR's anyway from another vehicle.
  10. FDR
    1,987
    135
    Jan 20, 2014
    Central NJ
    I saw the tire number and glazed over the rest, assuming they were summer tires or something.
    Good news, that tire is the right size. It's only 0.5% different in circumference from sport 235/50/17
    http://www.willtheyfit.com/index.ph...diameter2=15&wheelwidth2=8&offset2=40#content
  11. 1LoudLS
    9,904
    353
    Mar 31, 2008
    Ann Arbor
    nope. sure doesn't...
    maybe if I brake torque it to break them loose first... but thats it.
    but then again, I also drive around the water box so I'm not trying to hook with wet tires.
    even when doing high(er) RPM launches, the rear squats down, then the tire hook and it goes, even on the street. I cant imagine a stock LS having any traction problems on a nice sticky prepped track surface.
    if you're really lighting up the tire every time you stomp on it, You might want to look into adding a LSD locking rear so both tires will spin.
  12. FDR
    1,987
    135
    Jan 20, 2014
    Central NJ
    Or look into better tires
Share This Page
